Rowe Ami CD100-I Title Page Motor Needed
debontebros
Donor 2022
Dayton, Ohio
Does anyone know if the have a working title page motor for my Saturn II?
The model number on the motor is:
merkle korff #40877101
Thank you!!
I probably do let give me some time to dig lol. I have bookoo rowe cd100 parts all models
You probably already know what it looks like, but here's the one I pulled from my jukebox...
No thats helpfull i have a box in my shop called "small motors" and its nothing but rowe title rack and animation motors filled lol. To be honest it was rare to for those to fail but not the I J H K where they were vertical up and down pages. After replacing this they will need realigned and i always dreaded this on those models. If i do ill send it for free and you get get me back if it works lol i can check it by hand turning it but that dosent really tell you much. Ill dm you monday it tuesday snd see if i have one.
I guess I never really tested the motor... The pages would not turn when pressing the up and down arrows on the keyboard.
Everything else works perfectly. I can enter disc # and track on the panel and it works well. That's why I thought it was the motor.
Can I use an electrical meter or something to make sure it's bad?? I've never done that before, but I do have an amp meter.
Thank you for all your help!! I really appreciate it!
Douglas
Douglas
Might be some bad solder joints? I'm not familiar with the cd models but I do know my r86 had a few bad solder joints on a few spots that caused some buttons to not work all the time
Since its a Saturn they have digital touch sensor buttons and not the white press button keypads all other models did. On the white keypad ones those could be cold or broken solder joints especially on the page flip buttons because they were used the most. Or the button itself needed replaced and just soldered a new one in. Now if it is a saturn with a digital keypad if i remeber right it would make a beep noise everytime ypu touched a key, this let you know that the button was working if it would beep after you touched it.
The keypad controllers did go bad with those. Does it beep at all when you hit the page buttons?
Douglas
Sorry using my phone and forums a bit hard to navigate on it lol. Anyway yeah see if it makes the beep noise when you touch the page flip buttons. Also you can Disconnect the two wires going to the title rack motor and hook a multimeter to those leads. Think that motor uses 28v dc it will day on the motor. Now its going to read nothing but when you hit the page flip buttons you should see voltage as every time you hit the keypad this would tell the motor to turn on and flip
Not sure if I mentioned this earlier, but I've removed the motor from the unit. Yikes! LOL
I should have waited, but I thought I could do this myself. I couldn't find anyone in the Dayton, OH area to come look at it.
Thank you again for all your help!
Huh ive never seen a saturn with the regular key pad and not the digital one. I do not have an extra title rack motor for that one unfortunately, i do for about every other model lol.
With those keypads just reflowing the solder on the back of them usually went a long way.
Have you tried contacting local amusement operators in your area? Easiest way to get their number is go to a local bar and look for stickers on their machines.
If you have the manual its possible you can do it yourself it does give you some pictures and explains the process of how you have to realign them once you put the new title rack motor in its just a headache, ive prolly done it 100 times, but even I struggle with them and usually have to redo it 3-4 times before i can get both sides in sync right or it will snap the title pages.
You can get a new motor from rowe still but idt you will like the cost rowes always been super expensive on all their parts.
I know this is an old thread but I figured I'd try here first. I'm trying to connect my CD100-A title rack up to an external power source and button that can flip the pages without needing the jukebox to power anything. Do you think this is possible? Thanks!
