Rowe AMI 1964 JBM200 Restoration help
Garageguy23
Bayport, Minnesota
Hello,
I just purchased a 1964 "Tropicana" that I would like to restore. I cleaned it up and am able to get it to play a single record if I turn the cam clockwise by hand.
When I enter a music selection, the search unit engages and then turns off without playing a selection. Also, the magazine doesn't turn.
I assume that there are several things that I will need to fix, but I am looking for guidance on what I should start with first. Thanks in advance for any advice.
get the manual and it shows how to rebuild the search unit.....that will get the box to play a song. then I'd go thru each unit (keyboard, amp, power supply, etc) till it is working like new. if you run into something you need help with, post it or there may be a local service company that can help you.
