I usually do not work on vending machines. But this one is a freebe for the local Fire house.
THey have not used the machine since 06. Yet as the fireman were emptying the machine they started to try the candy bars, chips and gum. yeah! They all agreed that the Snickers and the Babe Ruth Bars still tasted ok ,but the Reeses Peanut Butter cups did not. The Nacho Cheese Doritos smelled like Wax. And so on.
On the front display it comes up with @@@@@@. I can open the door go into the programing mode. set prices, set change levels.
I am unable to put in the date.
In the Key 5 set to COIN COUNT yes for the smart coin counter.
I set the Nickel,Dime and Quarter levels. It showes me the levels I put in after a power down.
I cannot manually ask for any change by pushing different buttons while in the KEY 5.
no link
POS message looks like I changed it. serial number,unit number I did not program in the lock out. no security code.
THE DBA is set to NO at this time.
Test the motors. I get a price fault if I leave a tray out and pull the white plunger out.
When all is said and done and I close the door the display indicates SYSTEM OK then goes to @@@@@@@@
No initial error codes on the front display come up after the door is open.
No response from the Coin MECH. I do have the logic 5 volts and the 24 volts going to the coin mech.
There is a 15 pin MARS TRC-6010 installed.
Any Ideas?
RJ
no link
Any Ideas?
RJ
