ROTJ pcb, should red light be on?
HighScoreSaves
Donor 7 years: 2013-2019
Blaine, Minnesota
Wondering if anyone can tell me if hte red light on a Return of the Jedi pcb should be on or not.
Mine is on.
Powers up, monitor has power, no pic, no sound.
Any ideas?
The red led should be lit. Check your voltages on the board to make sure they are correct.
-Brian
Check.
All voltages are coming up correctly.
Just getting glow from the neck, light is on, coinlights work, etc.
I'm stumped. starting to think it's a wiring harness issue?
Checked the pinouts and they look to be correct...
Not enough information to isolate as you may have multiple problems (PCB / amplifier on AR / monitor). I can tell you that all ROTJ boards eventually end up with bad roms (bit rot). If you have a programmer I'd check the codes of all of the roms for sure. If you need the board tested, I can do that for you. I have a test setup for ROTJ.
Bill
