Starting a thread to document everything I discover, fix and rebuild on this Getaway. 1st time tearing a machine all the way so have tons of questions and instead of having separate threads on each item, thought this might work. I don't want to call it a restore because not sure it will go that far.
Also, since I picked this machine up from a FS thread here on KLOV thought it would be interesting to document its life. Wish me luck.
History.
acquired via this post http://forums.arcade-museum.com/showthread.php?t=299754
List of parts to be ordered. (comments welcome) will update this as I go.
1) rubber ring kit <ordered>
2) coil sleeve kit
3) new legs
4) yellow target <ordered>
5) battery holder
6) pivot nut <installed>
7) cliffy protectors
8) new post sleeves <ordered>
9) new molex connectors, pins, headers.
Issues to address
1) slow supercharger speed @ 170 on speed test <fixed but untested>
2) part of GI not working
3) mars lamp works but not in diag mode
4) battery holder
5) possible chronic blown fuse issue F102 related to ball plunger. See http://forums.arcade-museum.com/showthread.php?t=300569
6) upgrade code to L2 or L5 (running prototype code PC)
7) tidy up some wiring hacks
8) left flipper sometimes sticks in up position (eos)
9) missing one of the pivot nuts for pivoting playfield in up position <fixed>
10) some water damage on backbox.
11) investigate connection on J134-9
History.
2) coil sleeve kit
3) new legs
5) battery holder
Issues to address
4) battery holder
