rollover on a 25" monitor
XcALiBrE
Asheboro, North Carolina
I have a SSB in the shop that has a decent picture on the 25" tube. little burn in, no big deal. It "scrolls over the top" so you see what should be up top "behind" the top of the screen. I tried adjusting some of the yoke rings... nothing changed.
cap kit maybe?
chassis model is a MakVision 2425 dual res.
I don't know for sure about MakVision monitors, but in general when things are folding over, yes a capkit usually will fix that.
The Yoke rings if you mean the rings that go behind the Yoke, those only adjust the convergence. Don't mess with them if you can help it, it'll cause BIG problems (the rings make the red/blue/green guns line up... if you move them, it's really hard to get them to look right again if you don't know exactly where they were).
I'd try a capkit first, one of the caps in the vertical section is probably bad.
Good luck!
