Rockola 7000 legend lighting question???
ghostrydr23
California
Does anyone know the legend very well? I am refurbing one and I have a small motor in the upper right corner of the cabinet next to a florescent light. Best as I can tell there is a color wheel or something that goes over the light and the motor spins it! Can't find anything in the manual about it. Any ideas on what the motor is supposed to do???
Thanx
Clyde
A speckled plastic tube goes over the bulb. Inserts in the ends of the tube ride on the bulb, similar to many Rowe boxes. Rubber belt on one end connects to a gear driven by the motor. Doesn't add much to the look of the box, PITA to change the bulb, expensive assed motor, assembly squeaks constantly unless you grease the end caps.
Let me correct myself here. I looked at one yesterday, there is no belt involved in the drive. The motor is attached to a plastic gear that drives a smaller gear on the end of the tube.
