slither
Hi guys, I recently bought a 1971 Rockola 446 jukebox. I was told it played fine, before storage a few years ago. It powers on, and you can make a selection, the dual arms spin around the wheel with the pins(sorry for the sad description, but I have never worked on one of these, only pins and arcade games) stops, then nothing happens.The record cradle does not rotate . The fuses are good, if I put the service switch to on, the turntable spins, off stops it and scan does nothing, the cradle should rotate at this point, on scan I am told. It seems the cradle end is not getting power, I was told there is a mechanical breaker somewhere that may be tripped, cant find it anywhere.Any help or ideas would be greatly appreciated. Thanks..
