neonut
I recently got a Rockola 445 and am trying to get it up and running. It was a workhorse that apparently lived a hard life in a restaurant. My main concern is that someone appears to have rewired the ADR .I assume it's rewired since it uses a five conductor cable and there are only two wires used. The wires appear to be nicely soldered to the ADR relay coil and travels down to the bottom of the Juke and stops. The wires appear cut, and there doesn't seem to be anywhere to connect the wires to. The turn table spins, when a selection is made the write in carriage spins and stops at the (correct?) stop, and that's all.
Many selection buttons won't stay down, do I just remove the whole assembly and clean it, or ???
