I know this is a learning process due to never dealing with jukeboxes before.
I recently picked up a Rock-Ola Trilogy 4000x jukebox.
I was able to find out how to open the unit and add the CD's that I wanted in it.
I know the system worked when I purchased it due to coining it up and playing the CD's that were already in the unit, but unfortunately after removing the existing CD's and adding the CD's that I want im having trouble running through the manual on how to map the new CD's.
As per the manual you put the system from operator mode to scan mode so that you can add the CD's. You enable the stop mode from the scan mode to stop the magazine to add the CD's.
After you loaded the CD's you put the system back into operator mode and set the dip switch 10 on the system to the on position to map the new CD's.
The problem is im not sure im missing a step because it doesn't seem to be scanning.
Does anyone have this jukebox and has programmed the unit to guide me through what im missing.
Any help would be greatly appreciated.
I've attached the pages to give reference.
I also attached what my dip switch setting that are on the jukebox currently.
