Robotron sounds....
Syngefinger
Michigan
I was playing my Robotron the other night, and in the middle of the game, the sounds became more and more loud. To the point where it was almost deafening loud. I shut it off using the back switch and gave in a few minutes. Upon starting it now, the sounds are back to normal levels, but the sounds are all "off". Almost like the sounds are from a different game entirely. Any idea what could be causing this?
Hi Synge,
You might want to move this over to the repair section if you can, to get more replies- my Williams game troublehooting is a little rusty, but I would check to see if you can get the game in a test mode of some sort. Usually it will do a test to see if any sounds play at all in the test mode. They may work in test but not during actual gameplay. You may also want to track down which of the boards in the game is your sound board and see if there is any visible damage to it.
Hope that helps to get you started!
VG
