robotron sound - i have none, but weird sound PCB voltages...
Klassic
Boynton Beach, Florida
game works now, but is new to me, so i don't have much of a history with it. currently, last issue i have is no sound. the weird part, is the sound board voltages are:
+13.8
ground
+13.14
+13.6.
are they supposed to be +5, ground, -12, +12, going from TP1 thru TP4?
everything else appears to be fine. fuses, power supply voltages, game play, etc...
From the schematics... it looks like TP1 - TP4 should be...
+12v (unregulated)
-12v (unregulated)
GND
+5v
thanks, jeff...ok, that explains those stupid original results...
checked correctly, i'm at:
+.65
-12.8
ground
+.53
cap it? at least the numbers now make some sense. ha...
Check fuse F2 on that sound board. If it's good, then the bridge rectifier BR1 is probably bad.
[edit]
Actually... if F2 is good... you may just have some cold solder joints on J1(the 9-pin connector near the corner of the sound board). Definitely check that before you go desoldering BR1 to check it.
thank you. both fuses checked out good last night (removed from PCB), but i went ahead and just now replaced them and cleaned the fuse holder on F2. powered up, now i have sound. guessing just a poor connection from sitting for years.
it was just a fuse...dammit. i usually don't post fuse questions...ha ha.
[edit]
