Madaracs
It had been running pretty stable recently but now it seems I've got a new issue and I thought I would ask other Robotron experts where to start.
This is a cocktail Robotron.
The harness was built from scratch by rhombus. It runs a little short to the coin door and there was an exposed wire that was shorting on the coin box. I think it caused one of the slow blow fuses to burn out twice. I taped that up and carefully moved it aside when closing the coin door... It worked great for about a month after that.
I'm thinking it's a ground or power supply issue but I was wondering if anyone else had a similar experience or advice they could share.
[Edit]
Found this:
http://forums.arcade-museum.com/showpost.php?p=1057545&postcount=6
I'll give some of that a try too.
[Edit]
Found this:
