eb94110
I have a weird issue going on with my Robotron.
Yesterday the monitor was recapped. When I started to play it again, the sound was going in and out and then stopped. I hit the reset on the main board, not realizing in the past when I had this issue, I had hit the reset on the sound board, and things were fine. When I hit the PCB reset, the screen went red. It said 131 error.
I tried to move the RAMs, and I still got the 131 message. I then moved around the connector on the upper left of the PCB, and I got a rug pattern now with a 111 RAM error. After moving that connector again and resetting the PCB again, I got this image.
@braedel did a great job rebuilding all these boards and p/s in the past two years. I can certainly check the p/s, but I wanted to ask if anyone had any other thoughts on what this might be.
Thanks so much.
Thanks so much.
