Robotron power supply led1 out
cueball
Coatesville, Pennsylvania
while i was at a house picking up a G07 chassis to recap, i looked at the robotron.. the LED #1 on the power supply was not lit.. the BR1 looked suspect as it had black globs off of the bottom edge. its cheap enough to order and replace, but i only want to order parts once.
thoughts??
If that bridge was bad, It'll usually take out a fuse. I'd also suspect the LM723.
Edward
Test the bridge to see if it is bad. Usually when there is black ooze coming out of them it is the culprit.
I've seen a lot of them look like that, but still be good. They're not so much oozing...as it's more "bad epoxy" job.
But I've also seen them go bad and ooze :)
Edward
Edward
Agreed.
The bridge can be tested, and proved either good or bad very quickly and easily. The LM723 is a little more difficult to prove bad.
It also depends on which fuse has blown. I had one last week that one of the diodes went bad and caused one of the capacitors to short internally without popping and the one fuse would blow, very slowly.
ken
