Robotron movement
rknucklez
New Jersey
My Robotron intermittantly will not move right. I kept thinking it was the joystick and rebuilt the wico and it still sporadically would act up. Today I decided to really investigate.
When I fired her up in test menu and activated switch test it read that "joystick move right"
was closed. I physically checked and the joystick was fine. I even turned the machine off, unplugged the control panel and checked again. It still thinks the joystick move right switch is closed. I checked all the wiring and that is fine. any ideas of where to check next.. If I turn the machine off and back on a few times it remedys itself but that is really growing old.
Thanks in advance
~RK
If the control panel is disconnected and the switch still shows as closed,
the problem is likely with the Interface (aka widget) board.
[smallest board in the cab.]
Not much on that board other than a PIA chip,
... which does go bad sometimes...
Happy hunting...
Steph
Try wiggling/reseating the ribbon cable from the cpu to widget board first, although bad connectors would not normally be effected by off and on cycles.
If the switch test is showing a closed switch and the connector is unplugged it is the I/O board. It may be one of the interface chips that jas gone bad, not necessarily the PIA chip.
If you have a logic probe, it is pretty easy to see which chip has gone bad. They are not that hard to repair most times.
ken
