SilverCoin
I have some questions.. and some noob questions. My first Williams game ya know..
When my machine finally came up I got a Rom Error 10?
The Digit display had a 0 on it, that was all, nothing blinked.
The display talked about factory settings and turning the machine on and off. I think the batteries are dead, can I just replace them?
Also I researched for Robotron help and found this nugget of knowledge:
The connector that has the orange wire in pin number 1 is where you want to take your voltage readings.
pin 1 -5vdc
pin 2 key
pin 3 +12vdc
pin 4 -12vdc
pin 5 +12vdc
pin 6 +12vdc
pin 7 ground
pin 8 ground
pin 9 ground
pin 10 ground
pin 11 no connection
pin 12 +5vdc
pin 13 +5vdc
pin 14 +5vdc
pin 15 +5vdc
My question on that is do I read it on the connector itself? or while its attached to the board. If so where do my leads go? I have a multi meter and used it in the past. Just not in a case like this.
The screen had a scrambled pattern for 5-10 minutes then booted to the rom error, then to the factory screen warning. The reset button on the inner upper board of the cab played a tune then explosions when I hit the plunger button. Sound test?
My guess is that my p/s isn't working till it warms up, and I need new roms burned. Also checked all my connectors and none of them are torched in anyway, very clean inside the cab.
thanks in advance!
pin 1 -5vdc
pin 2 key
pin 3 +12vdc
pin 4 -12vdc
pin 5 +12vdc
pin 6 +12vdc
pin 7 ground
pin 8 ground
pin 9 ground
pin 10 ground
pin 12 +5vdc
pin 13 +5vdc
pin 14 +5vdc
pin 15 +5vdc
thanks in advance!
