RoadBlasters sound effects not consistent
akeym
Donor 2012
Oregon
I've noticed during gameplay on my RoadBlasters cab that occasionally not all of the sounds will play. For example, occasionally I'll start a new level and the sound of the engine won't be there, but the gunfire will be, or the screeching. Other times it won't play all of the instruments/beats for the theme music. This doesn't happen consistently after certain levels or sounds, but it has happened to me multiple times (with power-cycling in between). It won't be the same sound effect or tone every time, and will "fix" itself either after a level change or by starting a new game (no power cycle).
I did the Sound Test from the self-test menu and it says the CPU is "good" and doesn't throw any ROM errors. I run in to similar sound issues when trying to play individual sounds from the Sound Test menu. I can play one sound number, scroll through to some others and play them, then come back to the first one I tried and it won't play again. Resetting the sound CPU will sometimes make it work again only to act up later. Often times the speech sound numbers (~95 and above) just won't work, despite the thing saying "speech chip test" when I go to the Sound Test menu.
I've tried re-seating the ROM daughterboard. I'm getting a consistent 4.98v at all 5v test points and on various ICs on both boards. I wonder if there's something wrong with the chip select logic? Or is this a known software bug?
Any ideas as to what would be causing this weird issue? Thanks
Humm
I wouldn't expect much help here on that board I have one with graphic issues not one comment on why it might be that way. I can tell you this I have two roadblasters boards one works 100 % the other is missing a bunch of graphics, the one that is missing all the graphics past every test the system 1 offers yet half the graphics are not there. I would check the 3 audio eproms for any corrosion past that I'm not sure.
