GameyMcGame
Resetting virtually very time the left flipper is pressed during play. 5v on the power board is good. I'm going to check the flipper board for bad solder etc and swap power boards with my fishtales to see if I can isolate. Any other thoughts?
Also, i can't seem to get the volume/test buttons to do anything. Interlock switch seems to work as the warning comes up on the dmd whenever I open the door.
Thanks for any help!
