Rommager
Hi all,
I have used 2 semi-working Road Blasters control panels to make one good control panel, but I am still short on control panel parts to complete this project (2 control panels didn't have enough parts - Go figure)
I am looking for a place to get replacement switches for the steering wheel buttons for Road Blasters.. I have been looking around Bob Roberts, Happ, etc, but trying to find this specific type of switch is like trying to find a needle in a haystack! The best way I can describe it is as a PCB mount plunger switch that is attached to a tiny PCB and is mounted in the steering wheel.
Also, for anyone familiar with Road Blasters switches, you might also know where I can get the little red actuator that fits into the plunger on the switch, and allows the button cap to successfully depress the plunger.. Yea, I need one of those too..
Finally, the steering wheel grips are loose and wobbly. Was there originally some grommets in the steering handles that snugged it up, or did they just get sloppy and loose after constant wear?
Thanks in advance!
Thanks in advance!
