kcfreeloader
I, for some reason, still cant use my circular saw with my right hand, and so it seems to blow the sawdust into my face, for example.
Circular saws are a weird duck. A typical sidewinder which is made for righties, exhausts to the right and rests on the keep side of the wood. But to see your line you have to swing your head over the blade to see it. Also if you cut the board without it resting on something (ie holding the board and cutting it) you have to cross your arms and hold the board with the left and cut right. Worm drives are more set up for left handed people. With exhaust to the right, the blade is in a better position to see the line, but the saw rests on the drop side of the wood, which isn't good either. Worm drives are also much bigger and heavier, but if you are left handed they would be the way to go.
As far as games go, my left hand is darn near dyslexic. Though i do all right on stuff like DK using left, when it comes to play games like time pilot, i have to cross my arms to play. Anyone else cross their arms to play games that aren't set up to play ambidextrous?
