RGBS to RGsB troubles
neosamuri
St. Albert, Alberta, Canada
Hi,
So I have an Arkanoid cocktail cab that the monitor has died. I have a 19" lcd to replace it with and I have been able to adapt and display the signal from the game board to the lcd. I have done this by putting the red and blue to there correct spots on the lcd's RGsB input and the sync wire is attached to the green input on the lcd. The green color from the game board is also attached to the same input as the sync on the lcd. The picture syncs fine and the red and blue come through just fine on the lcd but the green doesn't show up very well. Have any of you had experience in converting an RGBS output to a RGsB(SoG) input?
Thanks for any information you can provide.
