TheBasement
Revolution X: What's the difference between Proto 5 and Rev.1 chipsets?
My old boardset has Rev. 1 Roms in it but due to non-working sound and some questionable legs on the sound roms, I picked up another Revolution X boardset. This boardset has a Proto 5 romset on all boards and is a verfied working boardset.
I was wondering, is it worth it to try to rechip it with the Rev. 1 roms? I know it should be a direct swap and the same boards will work. Does anyone know the differences between the chipsets (gameplay, sounds, etc?). Also, if you know anything different about the Rev. 2 chipset then chime in.
Thanks for any info you might have.
