Revolution X & Terminator 2 in one cab
Stryker28
Donor 2012-2013
Hanover, Pennsylvania
OK so I have both Rev X and T2 in my Rev X cab. I have a double JAMMA switcher installed, every things hooked up except the harnesses that connect to the guns. It's easy to hook both boards up to the four start buttons but how do you hook up both boards to the guns? They only have one connector to each. Do I splice them into one another and then hook them to the gun or do they make a two & one connector? If anyone has done this before any help is much appreciated. Hope I explained this right. If you need more info just let me know.
I think you sorta figured it out. You use the same wire on both connectors. Since they use those self-splice terminals, it's easy to do. You might need to grab some extra wire and just run a longer wire with both connectors on it, or you might be able to pull a little slack, splice a few inches up from the end on game 1, then extend the wire to splice to connector 2 by solder or butt joint. (yes i said butt and joint next to eachother!)
