Where does the sound pot go on this board set? I am used to other Midway board where the sound pot is directly connected to the sound board. Thanks in advance.
Rev X has a seperate sound board that is known to fail and as I understand it no current way to repair it without replacing the soundboard with a known good one.
Correct, there should be sound to the speakers. The manual mentioned checking connection at pins L and 10 at the jamma connector, volume setting, check for 12vdc at pins F and 6, as well as the fuse on the sound board. (located under P3 (2a slow blow 5x20mm)) (interesting that there's a fuse built into the sound board)
Correct, funny enough it's called an X-Unit, it's definitely unique and the only one of it's kind, the soundboard is similar to a MK2 soundboard, and the main looks kinda like a wolf unit.
I've never seen a Revolution X setup, but if you ever saw T2, it actually used headers on the sound board to connect the driver board. and there were lots of fuses in that game lol
