MonsterBash
So I got to mess with this for about 3 hours last night..here's the details.
I have zero output from the monitor...no chatter..no 'white dot'
Spot Killer is NOT on..game plays blind
New Big Blue
The boards were caped with BR deluxe kit about 8 year ago and were never installed. The guy who did the cap kit looks like it s real nice job...I re~flowed a couple items including all pins and wires that run through the board on the neck, deflection and HV.
I installed a LV2000 and had proper voltages at pins 2 and 6 (I think those are the pins)...I had -26 and +26 exactly...with the deflection board on the bench. Both LEDs are red
I get nothing for B+ on the back of the neck board or pin 5 (I think...orange wire) on the HV..I also get nothing for 26V
I tested d100-104 and the are fine at .45..fuses buzz fine
I followed the 6100 FAQ to the end...the components calling for 'replacement' were replaced in the cap kit. I checked continuity on all caps to their traces and continuity at both sides of the plugs from the game board to the monitor
I do have neck glow and 50V coming into the chassis
All 6 chassis mounted transistors have been replaced and new isolators. All have been tested for zero continuity to chassis and all show +30V or -30V. I did find that a couple where mounted in the wrong spot on the chassis (when I replaced them all)..only to find out that the wiring was also wrong (which did match to the proper transistor). I reinstalled the transistors in their correct location and matched them to their proper colored wires as per the faq.
One thing I found interested is the pic below with the chassis mounted transistors
New Big Blue
