hmmmmmm...
I am spending at minimum 5 minutes in each game.
*** My ratings are on a scale of 10, I don't really mean 10 as Direct PCB quality if you know what I mean, If I say 10/10 I mean its the best it is going to get as far as the emulation, I really feel if I put 10/10 I think its perfect.
GNG doesn't have any delay. What I noticed on mine was when you're running the system seems to not be able to render the entire screen fluidly. It runs at the speed it should but it almost seems to flicker at times. I love GnG and spent many dollars playing it growing up so anything less than perfect is a bit of a letdown.I know the cps3 games are unplayable, but I feel my GnG never has a slight delay,
If you check my VAPS I do own the actual hardware for SF2, SF2CE and until recently SF2 HF. I actually have multiples of SF2 and SF2CE I just didn't list them because it's quite a few working and non-working.I find most of the sf2's even the bootlegs to run great and I play that game almost every day on xbox, mame, and actual hardware.
Yeah sure thing. Or you can always drop by next time you find yourself in Houston.If you are ever comming over to the Austin area let me know. Id love to put that into one of my cabs and see how it runs.
I finally got a chance to wire a cab up for the Blue Elf 2 that I have and I have to say that mine sure doesn't run as good as yours does StreetzKing.
Yes the Blue Elf, this is the Blue Elf V2 2009! lolDidn't I tell you to stay away from the Blue Elf?
Thanks!hold start and insert a credit
