Reverse image?
cascadecomic
Federal Way, Washington
I picked up a cheap non-working Space Invaders a while back and finally decided to start working on it. Turns out the board set is good it was just the monitor. I've replaced it with a Electrohome G07-CB0 and got it up and running pretty good. But I need to know which wires to swap on the yoke to reverse the image. Anybody know?
The horizontal winding is red and white. The vertical winding is brown and grey.
To reverse the image, swap the polarity of the associated winding. For example, to flip it vertically, swap brown and grey. To mirror it across the horizontal, swap red and white. Don't mix the wires between horizontal and vertical windings or else you'll blow stuff up!
The plug breaks into pieces pretty easily, so you can rearrange the wires.
-Ian
