Return Of The Jedi
flynn54321
GREEN BAY, Wisconsin
Does anyone know who might be able to repair a Return Of The Jedi board?
I had mine working but there was hum in the sound - now all it does is comes up with garbled crap on the screen.
I had the same thing with mine. I rebuilt the edge connectors and that seemed to help...for awhile. Now I'm having the same issue again, but I think it's a voltage problem...I've got too many games on one circuit. Post what you find out if you get yours repaired.
Derek
I'm sure you've already reseated your edge connector...but try it again anyway. I also had a couple of burnt pads, so that could easily be your issue.
I'm bumping this because I'm dealing with the same thing. Mine will work okay for a day and then weird stuff again. In addition to getting occasional garbage, and a mild hum, I now have a steady "clipping" sound coming through the speakers and my screen can't stop rolling. I've adjusted the monitor all I can, but it's impossible to get the image steady. I'm going to give El Dorado a call and see if they work on them.
