Zitt
I recently purchased a
Pacman retro-arcade 10-in-1 board set for use with my stock Pacman board which is part of my worklog - however, the kit did not come with any instructions.
I finally got my machine back from a work charity event; and attempted to install this retro pack. I did the obvious and no-so-obvious things. IE installed in in 6B. Put the connector in 5E. Removed all the ROMs at 6E-6H. I get a tone... and what sounds like menu movement when I move the joystick. I left in the ?Color Proms? at 4A and 7F... and it gave me some garabage on the screen but the pacman ghosts appeared and the game started with sounds. After removing the color proms; I get a white screen.
Obviously I'm missing something in the configuration of this board. A DIP switch setting?
The board is labeled
"retro-arcade (C) 2002
All Electronics
CPU Board"
Does someone by chance have an install manual or know how to install this puppy correctly?
All Electronics
CPU Board"
