Retro Arcade (Arcadeshop) Vector Chassis (WG6100 replacement) Q's
Hey,
I picked up a Tempest the other day w/ a strange vector chassis... after a little searching I've found that it's a Retro Arcade chassis (both HV and Deflection board), previously sold by Arcadeshop.
Anyway, is there any technical info, troubleshooting, schematics, etc anywhere for these? When I turn it on, it plays blind, and I hear deflection, but there's no HV. On the HV board, the "Low Voltage" LED is lit. I'm not sure if this means the input voltage is low, or my assumption is that it means the B+ is low, and in effect HV is low (so the LEDs are a way to tweak the HV w/o any special tools).
Does anyone know anything about this board? Is it basically just a copy of the 6100, so I can troubleshoot w/ 6100 docs (and did they keep the same component numbers), or is it a totally different design?
Thanks,
DogP
Hey,
Thanks,
DogP
