RESOLVED: Tempest - bad output on "Y" & scaling issues..
Just got the monitor issue resolved (see here).
EAROM wasn't working (not saving high scores), so after putting several games on the monitor to verify it was solid, I shut down, and powered back to confirm it was indeed still not saving scores.
As fate would have it, my board has now decided to go down - I'm getting this output, consistently - both on the monitor, and on my scope..
As per this post, it sounds like I can connect my scope leads at the first TL082 after the DAC, and before the MC1495L's to see if I get a good (albeit smaller) image. If that image is good, I know the issues are downstream. If they're not, then I'm guessing I'd suspect an issue with the DAC @ D10?
Would this equate to pins 9 & 11 on the 74LS04 @ J11, or should I go with pin 1 off of A11/D11?
All voltages in the area checked out as well... Going to pick up a bunch of TL082's (NTE858M) tomorrow; the one at D/E13 was already socketed/replaced by me when I was originally repairing the board, so easy enough to do a quick swap on it - others are not socketed however. Want to make sure whether I'm likely dealing with MC1495's/TL082's vs. the DAC, since if it's likely the MC1495's, I'll be putting an order in to get a batch from China which will take a while...
Appreciate clarification/insight! Pretty bummed that I finally get the monitor solid, and the boardset (which had been solid for a good while) decides to die immediately afterwards
