[Resolved] Tapper MCR video with lines issue
Couldn't you just lay all the boards out on a flat surface and flip the entire assembly based on what board you were probing?
Ty for the suggestion @KaBoom1701. I don't have a test rig setup so the only thing I could do is lay the boards outside the back of the cab so it gets power while I probe. I could try that but I already sent the boards for service. Thx again for the suggestion
You are an idiot that doesn't know how to read. I completely disconnected the exposed board so only the middle boards were running and the problem was still happening. Maybe try take a reading class and come back with better insults next time.
Shocking that a video problem wasn't being caused by the sound board!
If you could ACTUALLY read schematics as you claim, you'd be able to figure out what the 3 boards in the stack do.
I am done with you sir. You are a waste of every one's time and hope you find what's wrong with you some day. You are not worth me interacting with you anymore
Good Lord this thread turned ugly from both sides for exactly no reason. SMH.
I would say both sides. It was totally unnecessary.
Just to close the loop on this thread. Turned out to be a bad 82s212 ram chip. @cdjump said he never seen that go bad before. Big props to him for his help and ty to all for your suggestions.
Shocking!
It was a problem on the vidgen board just like I said it was (not the "middle board" ie. CPU).
If you'd been able to figure out how to probe your boards the line rams would have been the first thing to check.
