Resistor replacement help
dyno
Lower Mainland, Britsh Columbia
I have to replace a 330 ohm 30 watt ceramic cement wire wound resistor on my mtc 9000 and I can't find a replacement resistor of that size an make, there doesn't seem to be anyone selling ceramic cement wire wound resistors with that high wattage. My question is can I replace the ceramic cement resistor with an aluminum covered wire wound resistor? I have found one that is 330 ohm 50 watt.
I've gotten those from Bob Roberts in the past. They've never been on his web site...I always had to ask for them.
Edward
