resistor question
mrcain
St. Clair shores, Michigan
I need to know if I should replace a 68 ohm 2 watt fuse resistor with a 68 ohm 5 watt fuse resistor on my G07 chasis. I don't want to fry anything .thanks for any help
higher wattage just means it can handle more power before burning up. The ohms are most important here. As long as you don't go below the recommended 2 watts, you'll be fine....
