need to get a 33k ohm resistor for the mute circuit on my tron board. question - all i can find locally is a 33k 1/2 watt, where the original is a 33k 1/4 watt. will the 1/2 watt work, or is that a bad idea? didn't know if it was similar to a cap where you can go up in voltage rating as long as the value is the same.
