joemagiera
Thread Manager
- Joined
- Mar 22, 2003
- Messages
- 6,162
- Reaction score
- 1,073
Hi,
Would anyone with a fully working Tron PCB, either in a game or on a test bench, be able to assist me with some testing?
If you might be interesed, I can let you know up front what is required:
You'll need to take the marquee off your cabinet - not as easy as it sounds because they usually have security torx screws holding them in.
You'll need a device that can take digital movies with sound. It does NOT have to be a high resolution device. Just something where I can see the screen and hear the sounds. Actually, a medium or even low resolution device would be fine, as those would produce more easily emailable files.
I'll ask you to take some specific videos going through the test menu. I need the marquee off because I want to try the tests with various speakers connected (and not connected).
If you are willing to help it out, it would be much appreciated. It should take less than 20 minutes.
Please email me direct if you can/will help. Thanks,
