FS Parts: Reproduction cardboard monitor bezels - MOST Atari + T&F, Red Tent, Exidy 440 - 2018
joeycuda
Madison, Alabama
If buying multiples, I can combine shipping, and possibly knock some off in larger quantities and save you $.
These are cut from a satin sheen black (solid black core) matte board, stiffer than original. The original Atari bezels were black ink screened on cardboard and just not feasible to do it that way. Each is cut from a template made from an original bezel. All cuts, prebent folds, scores lines, are razor cut and match the original exactly. I include the heavy duty double sided foam tape for assembly when applicable. When installed, these will look correct and fit perfectly. If someone is not satisfied, I will take care of it. These are shipped flat with plenty of sturdy cardboard to ensure safe arrival. In a few years, I've had maybe 2 instances where a package was damaged in shipping.
Just shoot me a PM with your wants and needs. Thanks..
Prices as of Feb 2018
$25/shipped
-Missile Command cabaret
-Asteroids cabaret
-Atari Warlords cocktail
$40/shipped
-Tempest upright
-Tempest cabaret (black)
-Centipede cabaret (blue)
-Dig Dug cabaret (black)
-720
-Battlezone UR (black portion only)
-Millipede
-Crystal Castles
-Assault
-Toobin (blue)
-Missile Command UR
-Centipede UR (blue)
-Lunar Lander
-Space Duel
-Black Widow
-Lunar Lander
-Paperboy/Championship Sprint
-Star Wars UR
-Exidy 440
-Pole Position cockpit
$45/shipped
-Pole Position 1/2 upright
-Major Havoc dedicated
-I Robot
-Return of the Jedi
-Atari System 1 (Marble Madness, Peter Packrat, Road Runner, Indiana Jones)
-Gyruss (original large piece is now 3 pieces, plus the small piece, so 4pcs total so that small enough to ship flat)
-Pole Position Euro upright (large flat)
-Quantum (large flat)
-Track and Field upright only (3 pieces - the large piece and the 'wings')
-Nintendo Red Tent bezel pair (2 bezels, 4 actual pieces)
$50/shipped
-Donkey Kong/Donkey Kong Junior (monitor bezel and the rear flap set)
this isn't really related to your for sale post but wondering if you had any videos or your construction process or general bezel creation.
I am wanting to create a scored and folder cardboard bezel for my Rampage cabinet which I upgraded with a 25" monitor.
Just not too sure where to start since I'm not a papercrafting artist.
Ugh....I wish I would have seen this post a week ago before I cut my own T&F bezel. I would have been more than happy to pay the $45 to avoid that chore.
How about the blacklight reactive, multicolored one for an Omega Race upright?
Can you make the one for a Space Duel/Black Widow/Gravitar cabinet that has the Amplifone monitor fitted? It is different from the one used when a 6100 is fitted.
I can't say for absolute sure, but the tube would be the exact same size. I can't imagine the tube vs the cabinet would be shifted 'much', and the bezel would have a little wiggle room, and there's screen adjustment. I'd feel comfortable doing it.
I wish that were true. I used a 6100 original as a pattern to make a copy, and only when I was completely finished did I realize it wasn't close. The 6100 sits a good inch or two further back in the cabinet. It was enough that Atari has two distinct part numbers for the different bezels (see the BW manual).
I think you are right in that the curvature on the tube side of the bezel would be close to the same, and of course the top, bottom, left and right sides of the outer rectangle are the same... but the width of each of the pieces and their inclination would be less for the Amp version (and therefore the angle at each of the four corner joints less acute).
If you had a pattern to work from I'd ask you to make it but I think I'll try on my end. Will PM for a MH dedicated though.
Do you do custom bezels?
I can send you the details in a PM.
Brent
:D
Do you make one that will fit a Tempest cabinet set up for a horizontal monitor (Major Havoc conversion)?
If so, I would be interested in ordering one as well as several others.
Cheers
Kent
