Daviea
Permanently Banned - See: Ram Controls Forum Secti
Reproduction 720 Degrees & Hall Effect Lower Housing
Well, I've finally gotten around to getting my teeth into the lower housing component used in the 720 Degrees and Hall Effect controllers.
This is what I started with:
Yeah, a filthy OEM part, but it was in one piece and not TOO worn. I've definitely seen worse..... much worse.
So I drew it up in Solidworks and made some minor changes to beef up the rigidity and compensate for the new material/process I intend to use:
This is the underside of the new version of the lower housing. Note that the "pockets" are totally different. The original part was injection molded nylon. Injection molding requires that wall thicknesses be limited, which is why the thin walls are all throughout injected parts.
This is the top side of the new version. Essentially, this looks pretty much identical to the original from this perspective.
Somewhere along my testing, I decided that cast urethane was the way to go. Urethane compared to Nylon is an amazing material. It's wear properties tend to be pretty extreme. Plus, it's cost-effective for relatively low production numbers. There's no way I'm going to be making 100,000 of these things, so an injection mold really doesn't make much sense. However, if I had found that injection molded nylon was the BEST way to go, I would have dropped the money on the molds.
Anyhow, here is my very first cast urethane lower housing fresh from prototyping this morning. It has not received it's program of machining for the fine details yet, but here you can see what it looks like right now. The first 720 lower housing made in 20+ years!!! Pretty cool. Check it out:
Once I apply the machining to this part and test it out, I'll green light the full production run. Next on my list: upper housing.
Hope you guys enjoy the pics.
Dave
Dave
