Repro-ing a 25" Bezel , Technique???
jar539
New Orleans, Louisiana
I have the original cardboard bezel which came with my 720 and fits between the 25" WG 5515 Med Res Monitor and the glass shield. It is in decent shape but not great and I want to reproduce it as part of my restoration and for a few other KLOV 720 owners. I have examined it pretty closely and it seems to be two pieces, (top and left side)(bottom and right side) glued together with little tabs. Shall I just take a razor knife and some alcohol or heat and try to slowly loosen up and cut through the glue and then trace the two different pieces on a cardboard template and then cut out??? Or is there a better way??? I'm sure someone has done this already. I don't need to reinvent the wheel here. If I didn't mind spending a few $, what kind of business would do this??? What about dptwiz????
Thanks for any feed back or advice,
Jason
originally, they were die cut best i can tell. I bought black posterboard to try and trace/bend/cut some new ones. Atariscott i think even has the films for the dies for these.
