LCD Can be done fairly inexpensive....
Look at
www.geeks.com for lcd monitors.
Great prices and selection. Just be sure to measure the inside dimensions of your cabinet to make sure the one you pick will fit.
Price: around $100 delivered.
I assume your 60 in 1 is a vertical display?
You can either use the standard wall mount bracket or modify something to attach.
I just did this with a 25" monitor and got a 26" lcd to replace.
Price: $149 delivered
I took the base off the lcd.
Then I measured the exact height, width and depth of the monitor as well as where the existing mounting screws held the original monitor.
Went to Home Depot and picked up the metal brackets used to hang dry wall.
The idea is to use these brackets to slide the monitor in and have it freely supported.
Price: around $10 for mounts and extra screws.
Then connected the lcd, placed it in the cabinet with the support hardware and measured where to drill holes. Attached the hardware, put back in the lcd.
Also, I put tint on the existing glass - this makes it look nice and clean without having to figure out a new bezel.
Price: $15 for a huge roll of removable tint at pep-boys - enough to do all my cabinets.
I can post pics later if you need....
Chris
