Replacement Monitor for Sega Lindbergh Universal Cab
Moomert1
California
Well this may be a long shot but here goes.
Does anybody know where I can find a replacement Monitor for a Sega Lindbergh Universal Cab?
I took apart my cab...The monitor uses metal brackets which extend through the monitor casing which then gets mounted to a support board on the cabinet.
I would like to have a spare monitor in case mine goes out.
Lindbergh, what game? I think that system supports VGA output so maybe large LCD? I was putting large LCD's in House of the Dead 4 and they looked great.
Otherwise any VGA monitor should work.
Any lcd will work in theory. It's the actual mounting of the monitor which is the issue. Lindbergh monitors have brackets which are able to be bolted direct k y to the monitor. Those brackets then protrude through the plastic monitor casing, which then get bolted to the Lindbergh cab.
The monitor is a toshiba, model P320CB.
I'd have to see pics. I've put LCD's in lots of games that had CRT's in them originally.
I have a Lindbergh Universal and was looking for a replacement monitor as well. Only place I found that had any was Mo in the UK:
http://videotronicsuk.com
I didn't end up ordering one yet as my monitor still powers on and shows a picture, but it will need replacing eventually.
Ah ha. That cab already has an LCD in it.
Thats going to take some fabrication on your part to make aftermarket hardware fit.
I really like my Lindbergh cab..I just hate that it appears, the monitor can't be replaced without some modifications.
Not sure what area of California your in, but there's a guy in El Monte (so cal) with a warehouse full of Japanese games and hardware. He's got a bunch of Lindbergh's. He might have a spare monitor. PM me if you want his contact info.
I think I know who your talking about. He said he has no monitors...
