replacement knocker for night rider SS
Slug54
Indiana
The pinball life one would work. Pick the AE-26-1200 coil.
edit: make that "could be made to work". It needs something for the plunger to knock on and not fly away, or a different plunger with return spring.
More knockers here: http://www.pbresource.com/bells.html
Ok thanks,
I found the place where it looks like it used to be mounted and there is a little metal plate where I think it used to hit in the upper left corner of the head unit this is the area where the cut wires are taped off.
Thanks for the help.
It's just not the same without the knock.
Hey Guys.
The knocker solonoid arrived and it does not have a diode on it.
From what I understand the SS version of the machine requires a diode accross the coil.
I would like to pick one up if needed on my way home from work and get this installed but I don't have the schematic with me.Can someone tell me the part# of the diode needed?
Never mind,I got it. I put a 1n4007 in and it is working fine.
