Replacement for Simtek SRAM?
priglmeier
Donor 2016
richfield, Minnesota
I'd like to have a replacement for Simtek SRAM that is not battery backed RAM. Does anyone have some alternative ships / manufacturers?
Thanks!
-greg
Ok?
Can you tell me what Simtek chips replace #### arcade ram?
Looks like the Simtek 12C68 replaces 5101 RAM
What about 6116 RAM or other common ones? Web source please
No... those two chips are very different. Someone could create (and perhaps already has) an adaptor board that uses that NVRAM to replace a 5101.
If you're looking for a plug-in replacement for a standard SRAM (6116, 6264, etc.) you need to find the Simtek of the same density that uses the standard JEDEC pinout. The spec sheets for the Simtek chips are all on the Cypress website now.
