flynn54321
So I went to replace my Ice Cold Beer motors today. I ordered replacement ones from Riptor a few weeks ago and finally had a few minutes to do it today.
So I ran into a snag or two.
I removed the 2 motors - then compared the replacement ones.
1. there is no sprocket at the end of the motor shaft on the replacement motors. So do you try and get them off of the old motor shafts? If so.. how do you do that? Because I could not get them off. Then if you DO get them off - will they go onto the shaft of the new ones?
Also the mounting plate (to mount motors to the sprocket assembly in the game) does not fit. It will not slide over the center of the motor unless you drill the hole larger.
Has anyone run into this? And what did you do to fix it?
