Lomotil
OK, so I know by now that it's not a good idea to work on your games while under the alcofluence of incohol, but tonight I thought I'd hit the jackpot...
So, here's all I see when I used to power up my Space Invaders Deluxe:
Tonight, I thought I'd remedy that by removing all the chips and cleaning them with the wonderous eraser...
Here's how I started out - One beer, one clean working surface, and one PCB set:
Mistake #1 - one pin down.
Solution #1: More lighting...
Didn't seem to help, see "mistake #2" on the same chip...
A sudden epiphany occured, as I deduced that a single 'twist tie' from the local grocery chain would both conduct electricity and solve my problems at the same time.
The soldiering went rather well, considering my BAL at the time...
Mistake #2 - another 24oz can of Steel Reserve (over 8% alcohol)...
Mistake #3 - NEVER try to remove a single chip with your fingers alone, especially if you've been hittin' tha sauce.
If you do, your chip ends up looking like this:
And whatever you do, don't ever try to open your third can of Steel Reserve while working on your games...
In the end, my game still shows the same stationary 'garbage' onscreen... Anyone have any ideas as to what's wrong?
