wildwest3163
any ideas on how to repair the edges of the plywood cases where the layers have separated? Couple things came to mind immediately,easiest was to trim it off and build back up with wood putty or bondo, but what I was thinking about was to fill in between the layers with wood glue, then lay a 2x6 block along the damaged area and c clamping it down tight enough to flatten it and squeezing out any excess glue. Naturally after it dried youd have to sand/fill any defects, but would it hold? anyone went this route?
