Guided Missile it has a black light that lights the plastic back drop i know i will need to repaint the back drop florescent yellow, plastic cracked missing pieces
is this 4" spot a hole or a tear? If it's a tear you will either have to glue/mend it together which might leave a seam. If a hole I would imagine you would still have to put something behind either just the hole or the entire backdrop. Since you say the original backdrop is plastic I would probably try and use plastic to have a similar look to it.
