Repair Log: Stargate MPU - Adjust Failure
YellowDog
In Memoriam
Donor 2011, 2013
Humble, Texas
Just finished fixing a Stargate board that was coming up with an adjustment failure every time it was powered up. There were two things odd about the board. The first was that someone had jumpered diode D9, which would have the effect of trying to power the board off the batteries or maybe somebody thought they could put NiCads in and recharge them. Anyway, it was not useful so I removed it. The other odd thing was that they had removed the pullup resistor R43 which would cause the input to the NOR gate at 6E to be indeterminate or low, basically making it as if the memory protect switch was pressed all the time.
After replacing the resistor, the gate was showing the input as low on the memory protect switch pin so I knew the NOR gate was bad. I removed the chip and put a socket in and replaced the chip. When I powered up with no ground on the memory protect pin (the equivalent of the coin door being open), the three messages flashed without the warning:
attachment.php
Press advance and it was game on, we have a working Stargate again:
attachment.php
I did circle around and jumpered the memory protect pin to ground (coin door closed) and it did give the adjustment failure message, just the way it was supposed to.
I love it when a plan comes together :)
ken
Ken;
Thanks for the post as I have a Sinistar that keeps giving me the "adjustment failure" whenever it's started, it also kills the battery very quickly.
That's a very cool little monitor - BTW!
Jeff
Ken;
Jeff
Thanks Jeff. It was one of the little 7" LCD monitors I picked up from a patchislot vender. I keep hoping he will get back to me with more, but so far no luck.
If the batteries are draining too quickly, you might also look into replacing diode d9 to prevent the batteries from trying to power the board when the AC power is shut down. Even a little leakage on that diode will drain the batteries fairly quickly.
ken
