What did the stripper do to the melamine under the art? Did it loosen/gum it up at all? I went the heat route, but it it does take a long time because the art tears a lot while you're peeling it off.
I only left the product on long enough to where it liquified the artwork which takes 5-7 minutes then i start scraping it off with a putty knife. The shit i use would eventually eat through the melamine if you left it long enough but for me, it did nothing to the original finish. Tron cabinets have the absolute worst artwork/adhesive to remove and the product i use CANNOT be used on the plastic shroud.
I've mentioned this product and showed pictures many times over the years, all you have to do is use the keyword search function. There is absolutely no artwork that i have had trouble removing with this stuff, it eats everything and won't damage the wood but you have to know how to use it.
